It was a number that isn't in my phone - so wasn't greg or tonyWhat's your number nick?
Wasn't Nicks phone either. My bet is it was Tonys brothers phone. Also Nick you did call people because I have 3 voice messages of you singing like a douche.
thought Id post a few picks of me prepping/wrapping myt spoiler. Ended up going with the Carbon Fibre Vinyl as the only black I could get my hands on with short notice was to glossy.
Setting up the work bench. [Knew that E85 drum would come in harndy]
Time to start wrapping. I've learnt the hard way that patience is key when wrapping anything..
Here is the spoiler wrapped and test fitted in the car. Will be interesting fit on the car as its not the "flushest" of fits but it should still look awesome.
luke gtr approves of this wing :thumbsup:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
