It was a number that isn't in my phone - so wasn't greg or tonyWhat's your number nick?
Wasn't Nicks phone either. My bet is it was Tonys brothers phone. Also Nick you did call people because I have 3 voice messages of you singing like a douche.
thought Id post a few picks of me prepping/wrapping myt spoiler. Ended up going with the Carbon Fibre Vinyl as the only black I could get my hands on with short notice was to glossy.
Setting up the work bench. [Knew that E85 drum would come in harndy]
Time to start wrapping. I've learnt the hard way that patience is key when wrapping anything..
Here is the spoiler wrapped and test fitted in the car. Will be interesting fit on the car as its not the "flushest" of fits but it should still look awesome.
luke gtr approves of this wing :thumbsup:
