Sarp whores
Watching Sabrina the teenage witch at work, yourself?
Lack of motivation that's what's happening round here!
Put on your motivation g string and get back out there princess tiddly pip :yes:
Sarp guys. Nothing like a switchboard to start a Monday.
Is that some mind of electrician humour? Like switch to start your moday.... Like a moday switch? Electricians are not comedians nope not no
Morning. Back in QLD, Best sleep ever last night
Those sleeps after you've been out all night and you get home and just die and you know you have nothing to do the next day.... Datsleep.jpg
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
