Apparently it works alright on the rbs. If it blows the bottom end, sure I can find a 30 bottom end for a case of beer.
My first R32 was a GTS with the manifold, turbo, injectors and 'cooler from a blown GTSt added to the stock motor after I lost my licence and had 3 months to kill.
Try a td06 on 2 litres and then come see me.
Why would I do somthing silly line that
A case of beer. .. and the 5000 dollar build to make it all work!
All the lags.
-5s I beleive.
brand new -5's indeed.
-5s are pretty close to too lazy on a 2.6 for my liking.
Bunta's right. -5 on 2.6ltr is pretty laggy in comparison to -9s (GTSS) or -7s (R34 N1s) and are more suitable for 2.8lt built engine.
But we will see what it delivers first before I start ranting on about how useless they are on the street.
Been there done that! Surge ported 3076 sounded amazing too and kicked hard. .. but the lag was :(
That's why I went 6 gears instead of 5.
And added AVCS (Subaru vtec yo).
And went E85.
And v-mount.
And Twinscroll...
Granted a normal sized turbo from the start probably would have been far easier, but where's the fun in that???
We could do this... Or have the ark running by then and take it down. Hence why I said take it off the road.
We could do this.
You never said what you thought of Adelaide wines...
How.
Does.
She.
Put.
Up.
With.
You?
I wonder the same thing sometimes
I'm getting mine done custom. ;). Only way to be. :)
I want a custom one for the Ark.
agreed. Mine are some hybrid thing based on 2510s and high flowed. They are good but can't recommend them to others as who know what the part numbers are lol
Yeah, I miss my old GTR number 1 which had GT-SS.
I almost put 2510s in it but sold it off 2 weeks before I'd killed 2 turbos after bit of faffing about and in the end a pair of GT-SS went in and was loving life.
Bunta. I purchased a 24 tooth cam disc item number DSM24t to try and mitigate some of the timing jitters when they raise their ugly head in the future.
Where from? To be honest, with your engine being brand new, I do think that is a solution that will work for you, and even if it doesnt at least Sean will know what to look for and be able to tell you if it didn't fix the issue
Yeah, they are pretty much spot on in terms of useable power
http://triggerdisc.com/
Sean seemed rather relieved after I told him that I swapped from PFC to Haltech.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
