Apparently it works alright on the rbs. If it blows the bottom end, sure I can find a 30 bottom end for a case of beer.
My first R32 was a GTS with the manifold, turbo, injectors and 'cooler from a blown GTSt added to the stock motor after I lost my licence and had 3 months to kill.
Try a td06 on 2 litres and then come see me.
Why would I do somthing silly line that
A case of beer. .. and the 5000 dollar build to make it all work!
All the lags.
-5s I beleive.
brand new -5's indeed.
-5s are pretty close to too lazy on a 2.6 for my liking.
Bunta's right. -5 on 2.6ltr is pretty laggy in comparison to -9s (GTSS) or -7s (R34 N1s) and are more suitable for 2.8lt built engine.
But we will see what it delivers first before I start ranting on about how useless they are on the street.
Been there done that! Surge ported 3076 sounded amazing too and kicked hard. .. but the lag was :(
That's why I went 6 gears instead of 5.
And added AVCS (Subaru vtec yo).
And went E85.
And v-mount.
And Twinscroll...
Granted a normal sized turbo from the start probably would have been far easier, but where's the fun in that???
We could do this... Or have the ark running by then and take it down. Hence why I said take it off the road.
We could do this.
You never said what you thought of Adelaide wines...
How.
Does.
She.
Put.
Up.
With.
You?
I wonder the same thing sometimes
I'm getting mine done custom. ;). Only way to be. :)
I want a custom one for the Ark.
agreed. Mine are some hybrid thing based on 2510s and high flowed. They are good but can't recommend them to others as who know what the part numbers are lol
Yeah, I miss my old GTR number 1 which had GT-SS.
I almost put 2510s in it but sold it off 2 weeks before I'd killed 2 turbos after bit of faffing about and in the end a pair of GT-SS went in and was loving life.
Bunta. I purchased a 24 tooth cam disc item number DSM24t to try and mitigate some of the timing jitters when they raise their ugly head in the future.
Where from? To be honest, with your engine being brand new, I do think that is a solution that will work for you, and even if it doesnt at least Sean will know what to look for and be able to tell you if it didn't fix the issue
Yeah, they are pretty much spot on in terms of useable power
http://triggerdisc.com/
Sean seemed rather relieved after I told him that I swapped from PFC to Haltech.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
