Apparently it works alright on the rbs. If it blows the bottom end, sure I can find a 30 bottom end for a case of beer.
My first R32 was a GTS with the manifold, turbo, injectors and 'cooler from a blown GTSt added to the stock motor after I lost my licence and had 3 months to kill.
Try a td06 on 2 litres and then come see me.
Why would I do somthing silly line that
A case of beer. .. and the 5000 dollar build to make it all work!
All the lags.
-5s I beleive.
brand new -5's indeed.
-5s are pretty close to too lazy on a 2.6 for my liking.
Bunta's right. -5 on 2.6ltr is pretty laggy in comparison to -9s (GTSS) or -7s (R34 N1s) and are more suitable for 2.8lt built engine.
But we will see what it delivers first before I start ranting on about how useless they are on the street.
Been there done that! Surge ported 3076 sounded amazing too and kicked hard. .. but the lag was :(
That's why I went 6 gears instead of 5.
And added AVCS (Subaru vtec yo).
And went E85.
And v-mount.
And Twinscroll...
Granted a normal sized turbo from the start probably would have been far easier, but where's the fun in that???
We could do this... Or have the ark running by then and take it down. Hence why I said take it off the road.
We could do this.
You never said what you thought of Adelaide wines...
How.
Does.
She.
Put.
Up.
With.
You?
I wonder the same thing sometimes
I'm getting mine done custom. ;). Only way to be. :)
I want a custom one for the Ark.
agreed. Mine are some hybrid thing based on 2510s and high flowed. They are good but can't recommend them to others as who know what the part numbers are lol
Yeah, I miss my old GTR number 1 which had GT-SS.
I almost put 2510s in it but sold it off 2 weeks before I'd killed 2 turbos after bit of faffing about and in the end a pair of GT-SS went in and was loving life.
Bunta. I purchased a 24 tooth cam disc item number DSM24t to try and mitigate some of the timing jitters when they raise their ugly head in the future.
Where from? To be honest, with your engine being brand new, I do think that is a solution that will work for you, and even if it doesnt at least Sean will know what to look for and be able to tell you if it didn't fix the issue
Yeah, they are pretty much spot on in terms of useable power
http://triggerdisc.com/
Sean seemed rather relieved after I told him that I swapped from PFC to Haltech.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
