Nope. This was German club continued by drinking at home.
BIG mistake that one - you only delayed your HO. Nothing worse than feeling like that at work. You should of kept drinking at work too :P
There is a bottle of JW Black on my desk. Before you start, it was gifted to me by a candidate who I placed in a job when every other recruiter said that she stood no chance. Even the guys in the office didn't think that I could. ;)
isnt he still on leave?
Nope. Started yesterday
homo.
why start back on a Thursday?
least make it Wednesday
Hey JW Black is ok. I just dont fancy blends. Good stuff re: placement for her - its evident you are dedicated to what you do. I will keep that note upstairs.
As a regular drinking whilst out whisky, don;t mind the stuff. Give me a call and I can give you the real details on what happened. You will be amazed.
was she a tard or something?
Hey Bunta, I highly doubt she was a tard. But a common issue / example that Tony may had to experience is when women leave the work force to start a family and then a few years after i.e. 3-5 years or more later rejoin the workforce. Nobody wants to know you which is despicable to say the very least.
I know a few women (CA's) who had to experience that, with one who was working with me here (my boss was respectful enough to take her on board) and was totally worth it because she has great experience and technical knowledge. She has now started her own practice.
I know, this was merely a outrageous statement to ease my boredom.
Anna is currently experiencing the same issue
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
