Apparently Mercury Motorsports NITTO ran a 10.1 tonight at the TnT. Guess they can only tune their own car and no one else's....
heard so many bad things about them (MMS) that I would not even bother. If they run that time it's because they actually spent the time and money to do it. That's all.
I was a customer for the past 5-6yrs. Only just switched as I've had nothing but problems the last 12-18 months. Nothing seemed to be going right with the car
I thought you were pro mercury?
Also I left before nitto got a run
take to it Godzilla motor sports. They know what their doing and get good results.
Ah fair call...
So what am I to do with my mercury Motorsport t shirt?
.... Keep it in the cupboard for trolling you lot that's what lol
Was talking to the owner or tuner or something of Godzilla tonight (his name was Darren i think, had an eye brow piercing) and had a chat about his "TUNED6" 32 GTR it did a 12.0 with no launch... Pretty impressive
Was talking to the owner or tuner or something of Godzilla tonight (his name was Darren i think, had an eye brow piercing) and had a chat about has "TUNED6" 32 GTR it did a 12.0 with no launch... Pretty impressive
like I said. They know their sh!t and deliver the goods.
I was for quite some time, but near the end they just couldn't get the car running right. I still think their setup and workmanship it great. But need to work on their customer service and tuning. Tuning is always very very rich, over the top so
take to Godzilla motor sports. They know what their doing and get good results.
Currently seeing All Star Tuning, Clint recommended them. Took it there, he cleaned up my e85 tune. Car made same power n 4psi less boost and with a cheaper version (non sucrogen) e85 fuel. And I only got charged $330!! 2hrs dyne time
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
