Finally caught up of this weeks whoring
So going camping again this weekend
Kinda in a bad mood. Kathryn saysshewill do one thing then gets here and is like nope don't want to do that we are doing this.... Dafuq.jpg
I hate when that happens - its an epic hope destroyer
Lol! Thought that you may like my snide remark ;)
Where is Anna? No whoring from her? Do I have to post-dig some of her previous comments to make it feel like she's here?
She never really did a lot of whoring and that was when she was in an office, now she isnt in an office she will be very rarely on here I would say
still need to wire HKS injectors, instal new vacuum lines, waiting for fuel fittings to connect HKS fuel rail to Tomei FPR.
lol typical excuses and big list of things to do.. first two no big deals, fuel fittings pfff call enzed if you are desperate..
welcome to wimin.
ants, I feel for you.
I really do.
tell the farker to finish it before he goes home.
its the least he can do for you being so patient.
thanx bro. its frustrating to say the least. It feels like an epic choke hold that just doesn't want to let go............................................so want to move on.
exactly
also not looking forward to do intank fuel pump install.. again.. :wacko:
why?
