So I had an interesting trip to work today, got caught behind a tradie protest, then they blocked our driveway for 2 hours, good times.
If you want more money finish high school you fecking plebs. :P
LMFAO
this looks amazing. and expensive? I'm not a big fan of wings though, I like the feel of the mouse pad against my thumb :3some:
And 5600 dpi is entirely unnecessary. my G500 is 5600, and the highest setting I use is 3000
I need the wings to keep my fat fingers off of the desk, they create drag while playing shooters, They are optional too.
It does 6400 DPI now and I barely use above 4000
Mine at work goes up to 5700. It has the ability to shift DPI at the click of a button on the mouse so it works well when head hunting and stuff.
Can have five settings at once. Currently I have: 350, 800, 1600 (most commonly used), 3200 (occassionally used), 4500 (for shiggles when anyone wants to use my laptop :P)
I got the Logitech G9x. Works well. Nice feel, balance and weight. Looks pretty. Has wing for thumb but not pinky which I like as well. :) $40 - not a bad buy. Work also gave me $20 for it so total cost to me was only $20 :)
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
