I'd still work. Probably buy out a few companies, properties and cars and keep working.
that would really depend on how much money you would win.
buying companies - pass
properties - yes (probably mix between residential and commercial)
cars - fcuk yeah!
do occasional consulting work - yes
cars - fcuk yeah!
I love buying significant shares in companies. Far better ROI than a house.
Buy bar, not give a shit about how bar does as long as it makes enough to pay the bills and keep me full of whisky, race cars, take photos of cars. There is my life goal
Boz, you need to be in Whoretown more often man
don't forget to build your own race track :thumbsup:
Boz u should buy a bar, and sell us all 3 dollar scooners and 5 dollar spirits of anything.
... I think that's fair
Kung fu them tony u Kung fu them good
HR have said that we aren't allowed to liaise with the Partners of this firm. I know a few of the Partners quite well and they chose to speak with me about vacancies, hiring and firing, market updates etc. Partner of this firm is looking. Caught up with Partner today. He hadn't seen a CV that I sent to HR a few weeks ago. Can't send it to him directly because HR will crack it and black list us from working with them again. HR won't get in touch with us to let us know what's happening. DAFUQ dude!?!
time to swap careers - become an MP for your local area- they get paid sh!t loads to do sweet F all!
Couldn't do politics. My past would catch up incredibly swiftly.
everyone in politics has a history. whether it be good or bad (usually more bad is broadcasted) doesnt stop them from being a politician. Just look at the quality of pollies of late i.e. Peter Slipper (Speaker) and Craig Thompson affair(s) they are great role models...............................cant believe that things like occur but hey their politicians they can do whatever they bloody want..............so it seems :dry:
Because I really want my past being dug up...
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
