I'd still work. Probably buy out a few companies, properties and cars and keep working.
that would really depend on how much money you would win.
buying companies - pass
properties - yes (probably mix between residential and commercial)
cars - fcuk yeah!
do occasional consulting work - yes
cars - fcuk yeah!
I love buying significant shares in companies. Far better ROI than a house.
Buy bar, not give a shit about how bar does as long as it makes enough to pay the bills and keep me full of whisky, race cars, take photos of cars. There is my life goal
Boz, you need to be in Whoretown more often man
don't forget to build your own race track :thumbsup:
Boz u should buy a bar, and sell us all 3 dollar scooners and 5 dollar spirits of anything.
... I think that's fair
Kung fu them tony u Kung fu them good
HR have said that we aren't allowed to liaise with the Partners of this firm. I know a few of the Partners quite well and they chose to speak with me about vacancies, hiring and firing, market updates etc. Partner of this firm is looking. Caught up with Partner today. He hadn't seen a CV that I sent to HR a few weeks ago. Can't send it to him directly because HR will crack it and black list us from working with them again. HR won't get in touch with us to let us know what's happening. DAFUQ dude!?!
time to swap careers - become an MP for your local area- they get paid sh!t loads to do sweet F all!
Couldn't do politics. My past would catch up incredibly swiftly.
everyone in politics has a history. whether it be good or bad (usually more bad is broadcasted) doesnt stop them from being a politician. Just look at the quality of pollies of late i.e. Peter Slipper (Speaker) and Craig Thompson affair(s) they are great role models...............................cant believe that things like occur but hey their politicians they can do whatever they bloody want..............so it seems :dry:
Because I really want my past being dug up...
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
