don't worry mate. Mine is also shitty. Needs a whole new respray from scratch. Just wont be doing that for some time yet.
At least yours is factory. Mine is a poor after market job. Looks like they applied paint with cotton wool balls
wolf in sheeps clothing?
Yeah it's factory crystal white. But it's age is taking its toll re paint wise. I will treat her with much TLC when she is back with me.
Also gnite mate.
Lies! They're always enjoyable.
No...... Imagine where your hands sit on a steering wheel and that it has a half windscreen. freezing cold morning and whilst driving the air flies through the windscreen and onto your knuckles.. Id rather stab my eye with a fork !
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
