That was the value to the company. The client has basically stated that they only wish to deal with the Director and hence I'm out of the process.
Thats a bit ghey, and also weird, who wants to deal with the director of anything, they never know thier ass from their elbow
Sucks a fat one, It happens to the best of us.
on some good news looks like I have sold my Apexi PFC ;)
That's great news, Money back in the sky rocket.
In other news I have the next 2 days off, Who is doing what.
It's happening more and more frequently which is where my concern lies. This, and then another client saying that they are moving everything in house, on top of the fact that SFA firms are hiring makes things incredibly tough. Our Director is actually hands on and does a lot of work himself.
Maybe it's time to look into ways to innervate your sales process, What can you personally offer your clients that no one else can and what can your business provide that they can't get anywhere else including internally?
Mugabe blowjobs don't count.
I was doing this. I had really strong connections with a number of the Partners and then HR has just come in and killed it.
Lean a lesson that I have just struggled with learning: Sometimes you will work our guts out to get something over the line just for someone else to come along and shit all over it.
If someone else screw's your deal then it is out of your control, Never take shit like that to heart it will eventually break you.
If your customers are happy and your boss is signing your paycheck then take the money and run, Alternatively live the Australian dream: find someone to pay you more to do less.
All of the time HR are dicks, No one ever implements HR propperly and the Power mad generally take jobs in that area. (If I offended someone with this statement then too bad)
Beer n Bitches fixes everything, Take a holiday and do something you have always wanted to do.
It was that major firm where I had the relationships with the partners and HR was allegedly holding things up.
Seriously contemplating resigning.;
well you know what they say 'if you cant beat them'..............................nah fuark that. Theses days you have to fight for what you want. Do not loose focus on that and dont give up mate.
This financial year so far has been apalling. I don't know dude...
lol......but you could offer it.
Mr Ants is it time to start whipping people over your car not being done?
yep, why me??? WTF did I do wrong??? I havent even paid Sean anything........bad luck????
Well I've got something to say to you mr bad luck.............................................F U!!!!!!!!! you dont control my life.
Gonna have to call Sean and see what the G O is.............FFS :verymad:
Well it would pay for Seans tunning costs I would imagine.
I have Friday off as its a public holiday here on the GC so looking at tidying up the house and garage so I can make room for 1. the new bub to come and 2. that stupid thing nick named ant-eater
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
