evening
And that's with a perfect driving record (no fines of any kind)
always helps
Because ls1
this
$1200 for the emo and agreed value of 23k, and i am over 25 :/
It's the agreed value that gets you. I'm sure mine would be alot cheaper If i dropped it down. I pay $1150 for my 33 and the wifes beetle, full comp, windscreen etc. Both on decent agreed values.
Thoughts on the wheels? Either the bronze or blue
And a funny because it sounds like mine
to flat! RPF1 :) I really want a set now.
My car plays a fairly substantial song too. I try to limit my arrival and departure times to reasonable hours lol
Mine is loudest at idle
Just say that you work for environment, show id tag and say that when checked it was legal. :)
Their nose meter won't be calibrated correctly if they have one so I can at least use that in my defence.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
