err, who is rb180 anyway, ry? Who else is going to this humerous dyno day from noosa..i might be in, to watch only cbf wasting money to prove what i already know...my cars not powerful.
No idea, cornhole reckons he is comming to watch, then we're going back to goldy. smash a few grand between us all on the pokies or something :(
Yeah come along for the snags, the cars and the social value...
No worries Josh...
Just make sure you do it before the 12th of Feb to avoid having to pay more...
We are pre-paying Richard for the day so we get in cheap cheap...
4wd dyno aye... Interesting *pounders* what I can flog from work over night.
P.s I miss sales, I was lying to myself when i said I was over it. You should get me a job baby cakes
$4.4mil in one month isn't bad from me seeing im a bogan :(
I'll try and get the coin in before the 12th.
You could get the juices flowing in here with some R34 shots of your car mabay Anna...
Were you at SCC 06???
Have we met before???
what's SCC?
LOL
I don't think i've met many peoples from here before....
my car is so standard.. LOL.. the pics aren't very exciting
what's SCC?
LOL
what's SCC?
LOL
Guest
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
