Well f**kya then Zaff, I was trying to help you out but you wont rerspond so forget it.
Hah sorry noel my computer decided it would get aids and I had to pop out this arvo!
No I am not a member as yet but am planning to join shortly as I have just gotten my license back as you already know!
kthnx...
Cliff notes:
Ive been a real estate agent since I was 18.
I dont have a car license, i need a part time job close to my house.
I applied at woolies.
oh, in that case, fair enough. Why dont u have a car licence?
17 - now Ive been a complete cock tard, went to court on another matter, police complied evidence over the last 4 yrs trying to prove I was unfit to hold a license and try and give a longer suspension. I surrendered my license to try and beat the system, no license no court.
No court meant a longer suspension cant be ruled. I ended up with getting the min time.
Which is?
good plan!
Cliff notes:
Kudos to you for getting off your ass and havin a go dude.
my lil bro just got his P's and got his first fine on the weekend and was absolutely deverstated cuz he didn't do anything (car near him did burn out, he got picked outta crowd). Hence the reason why 17yr old boys driving loud skylines shouldn't drive in mooloolaba on a saturday night! Told him to get used to it and avoid the area!
What the?
LOL at Josh workin at woolies
Imagines Shane asking him "are those bananas firm?"
Nismoboy replies "Do want a fist in your face?"
I wont last working at woolies aye. I need an admin job so i can whore on here all day
Yeh had to do something, sitting on my ass is boring, and pointless. Im spending more then I earn, which is a big fat ZERO. Woolies will suck, and I doubt i'll last, but its "something" I guess.
Plus its not even 5 minutes up the road.
Guest
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
