yeah f**ken SR's and they power to weight crap...going to be hard to beat into and out of corners....can only have her down straights and fast corners...will be interesting.
the last skyline that took me on ended up in the kitty litter
as if try and outbrake me
ps. i actually slowed down too much for the corner so he had to steer off.
what?!? I was scared ok, he was going really REALLY fast.
yeah.. it's nothing special
Nissan 180sx Specs
1994 Nissan 180sx – Red – RPS13
Power – ???
S14 SR20DET VCT – Aus Spec
GT28RS .86
Metal intake pipe
JJR 3inch exhaust
300x600x75mm Cooling Pro Intercooler (tube & fin)
HKS Pod Filter
S14 5 Speed Gearbox
Exedy 5puk clutch
Kaaz 1.5way Diff
S15 turbo Brakes
RDA Slotted Rotors
Tein Monoflex Coilovers
Koyo Drifteks 17x8 and 17x9 on the rear.
Tyres – Kuhmos semi slicks (however you spellt hem.
Bee-R pineaples
Momo steering wheel
It did a power run on the dyno at 140.6 before the new turbo went on... and i suspect that that power run was also done when the turbo i had on (t28) had a cracked exhaust housing.
your car is like 30kg heavier than Liz's not too much difference
except in the engine...unless you convert to the 25 in time
actually.. for the 3 laps i did last week, I was keeping up to some pretty fast GTRs and the Evos.
go team s13
Id beleive it, last time I was there the GTRs were slugs too, they were starting to get moving by about halfway down the straight!
Nissan 180sx Specs
Power – ???
GT28RS .86
Metal intake pipe
JJR 3inch exhaust
HKS Pod Filter
S14 5 Speed Gearbox
Exedy 5puk clutch
Kaaz 1.5way Diff
S15 turbo Brakes
RDA Slotted Rotors
Bee-R pineaples
Momo steering wheel
should go really well when you get that turbo cranking with some engine managment and stuff!
It DID go really well.. for 4 mins
lol
like.. remember when i drove my silvia up to see you guys.. and you let me drive your car and i was like ZOMG THIS IS DEADLY
that's how i feel now
Guest
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
