I know, not a real redhead... But who really cares??????
Quality I want quality rangas Rhinorebel!
Hahah your learning... Good, goooood :)
He is, isn't he! Im really proud of our little cowdy ;)
when run in, powertuned and issues sorted.
That's cheating Luke.
Ahhh ok then. They should make glass headlights for us :P
They can make anything glass, I've had a lot of custom order stuff, things you would think impossible from glass and they've made them.....basically I send a technical drawing, or better still the actual item and it can be cloned, or made better depending on what you want.
Would be nice to order something that didn't involve visits from the State Drug Enforcement guys, they thought they were onto something hot, until they realised it WAS an actual business.
They can make anything glass, I've had a lot of custom order stuff, things you would think impossible from glass and they've made them.....basically I send a technical drawing, or better still the actual item and it can be cloned, or made better depending on what you want. Would be nice to order something that didn't involve visits from the State Drug Enforcement guys, they thought they were onto something hot, until they realised it WAS an actual business.
Not surprising that would happen to legit business owners. Sounds really fascinating what you do and what they do. You should post some pics up for everyone to get a better idea.
lol, sounds like a fun day at the office.
Seriously though, ball park figure on a R33 series 2 headlight lenses?
Apparently I was "high risk" due to having a Chemistry and Pharmacy Degree and was ordering large quantities of lab equipment.....c'mon guys would I make it *that* obvious if I was up to no good? "Hey look at me!!!"
No idea with the lens cost, I'd need some dimensions etc etc to get an accurate idea, I'd say they will want one to play with and mould also as it's too hard from a drawing to get it right.
but we do not have r31's yet have glass headlights I wonder...........I wonder.......
Well they had to do something right with the R32's, i mean shit, they bodged up the body bad enough, the least the could do is stick some glass lenses on the headlights!?
Lens request sent, I'll see if it is possible.
I'd say they'll need both a complete L + R headlight to make sure all the clips etc etc are still functional with the glass replacement, yet retain the desired strength. It'll be lab-grade Borosilicate, so nice and strong :)
Guest
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
