  • 2 months later...
Adapting the 25 head to the 30 block is your biggest hurdle if you keep the stock bottom end, it depends on how much power you want and how much you have to spend, If you posted saying you want 400hp on a budget of $5000, I'm sure you would have some replies.
What parts do you have from the old motor, turbo, head etc?
A rb30 motor is easy to come by and fairly cheap compared to ours and if your old head is still good your set for a great motor but it all comes down to your goal. :D
I don't know, I posted for some help in the rb30 conversion thread but noone has come to rescue yet :nyaanyaa:
i like your style :D. i'm currently going through this saga with my gtr,...going to post a reply
I am getting an rb30 block from a mate for a carton of Jacks, and I am selling everything off my rb25 block that I wont be using to my boyfriend for his s13. I have around 5 - 5.5k to spend, I just want to make sure I am going to be ordering parts with a known history of standing the test of time. The turbo I have is a t70. This was her before she blew:
All the pics of the car were taken by the previous owner. The only photos I took of her was when they dismantled the engine.
More pics can my found in my sig link.
hmm could be hard to accomplish with only 5.5k. but seeing as you've got all the other bits and pieces, all ud need to spend that on is the engine, so could be doable.
whose going to be building it for you?
PM sent with some more info :wave:
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
    • Hello,   My name if Frederick, i'm 30 years old and I live in Belgium, Europe! I used to have a Nissan 370z daily but since I got a company car I turned that into my seattime driftcar. About 3 years ago I also wanted something older with more feel, so I got an R32 GTST with an rb26 engine. I am now getting the rb built to have around 800hp and it's close to being finished. I'm very excited for how it will drive and how driveable it will be! Regards, Fred!
