In 1914, the Kwaishinsha Motorcar Works, established three years earlier, in Azabu-Hiroo District in Tokyo, built the first DAT. The new car's name being the acronym of the company's partners' surnames:
* Kenjiro Den
* Rokuro Aoyama
* Meitaro Takeuchi
The Works was renamed to Kwaishinsha Motorcar Co. in 1918, and again, in 1925, to DAT Motorcar Co.
The next year, the Tokyo-based company merged with the Osaka-based Jitsuyo Jidosha Co., Ltd. (established 1919) as DAT Automobile Manufacturing Co. Ltd. in Osaka until 1932. In 1931, the first DATSON—meaning "Son of DAT"—was produced. However, the last syllable was changed to "sun", because "son" also means "loss" in Japanese, hence the name "Datsun".
In 1933, the company name was Nipponized to Jidosha-Seizo Co. Ltd. ("Automobile Manufacturing Co. Ltd.") and moved to Yokohama. In 1934, Jidosha-Seizo merged with a fellow Japanese automanufacturer named Nihon Sangyo Co. Ltd. ("Japan Industry Co. Ltd.") who was popularly known as "Ni-San."
The company became Nissan Motor Co., Ltd. on June 1, 1934, and was founded by Yoshisuke Aikawa.
Thanks Google :)
R32 60th Anniversary editions exist (see attachments). The 40th anniversary edition R33 models made in 1998 are probably to celebrate the 40th anniversary of skylines (not Nissan itself).
Yeah my r32 has 60th anniversary interior cloth, driving lights and spoiler - these were all options on the normal type-M!
Seems like its just a number of standard options banged together with a special key.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
