  • Replies 94
Posted Images
well it may be a direct bolt on, but it doesnt directly bolt on, at least thats what my car says :D
im guessing you werent doing it right
it should bolt on with 4 bolts
go outside, take a pic of your AFM (unbolted from the airbox) and take a pic of the filter
either that, or you bought the wrong filter
its the one for the z32 afm, which i assumed was the universal one
there was no adapter with it, it was just the filter, i need an adapter. i had a mechanic who works for an import joint try to fit it, and it don't fit. this guy knows he works on skylines every day
there is 2 gaskets with the filters
the one with square ends is the one you use.
test fit the gasket on the AFM... it will fit
then find the 4 of 8 holes in the pod that they line up to.
it will fit
It fits.
The Power Intakes come in a number of sizes, with different inlet diameters, and overall lengths. You gotta make sure you get the right one, some will require an adaptor, others (like everyone suggested) will bolt straight up to the AFM. My 2c is telling me you have one of the latter ones.
i showed everyone the one i bought and they sai its the right one.....so which is it.....im doing somethign wrong or ive got the wrong filter?
but lets forget about that for the moment. the issue now is where i can can a adaptor
Edited by anjoO
I believe you need the one wioth the part number 500-A022
I am pretty sure thats the one I have and it bolted in no problems. I think you may have bought the A021 version.
pictures show the A021 unfortunately.
i say sell it and buy one from nengun for less, you just have to wait ..
ffs is there any possible adaptors i can buy...damn wen i asked on these forums i was told all i needed was a pod...thats all....hrmmmmmmmm
What was the A021 designed for by the way?
Edited by anjoO
K&N make adapters
By the way - Im customizing an air snorkel for my CAI box..... will post up a thread once done, with pics etc.
Edited by Tangles
K&N make adapters
could u give me some sort of idea where i can get some and wat they look like (eg model name)
the adapter??? well looks like a normal adapter... ie one part bolts onto the afm via 4 screws and the other part clamps onto the pod filter.
as far as seriel numbers go - matey, GOOGLE is your friend
you may need something like this, for an rb25 of course:
http://cgi.ebay.com.au/POD-AIR-FILTER-ADAP...1QQcmdZViewItem
Edited by Tangles
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
