  • Replies 49
It sux not having a the Skyline any more, missing out on the cruising and especially now with the colder weather, it's turbo heaven.
I'll have to wait until i get another one imported from Japan. Can't wait though. Just holding out for the right GTR to come my way.
Those are all moderatly cool ideas lads......But if you want correctl;y test the cars power then you'll have to come to my place.
I have a pretty long driveway see, and We'll line the cars up one at a time, then launch them with me running full pelt from a standing start along side them, whichever one gets to the end with the most gap between the car and me, is teh fastest! :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
