  • 3 weeks later...
It Aint Pretty But she f**king hammers... RB25 in my 32
Oh and I decided to dummy fit the rear wheels... overfenders leave japland in 2 weeks, not long to go now and itll be 100% finished.
Dummied up the flare minus the overfenders obviously
All ghetto'd up with tape just to give a general idea of what she might look like when done, overfenders and finishing should make a big difference but you get the idea :blink:
By the end of the year the goal is to be putting down 600hp at the treads and to have all the cosmetic work finished.
Shit Camera. Ghey Sun. Clean 32.
Yeah very nice 32 man, luv those rims but what is with your camera? my fone takes photos much better than that... i'd be taking it back to the shop asap. heres one of mine (in progress) i took on the fone, getting rims soon then lower it and that will be it for a while before i go broke...
Here's a few photos i took today with a shitty point and shoot camera.
The front bar is off at the moment because of a little driveway accident. (driveway won)
Ive added a few pics of the damage to the front bar, if anyone has done this sort of repair before please pm me as I have never worked with fibreglass before.
Edited by FOG35
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
