To clear the above question regarding the side indicators on R32's it is my understanding that when compliancing these cars it depended on the person compliancing the cars interpretation of the ADR relating to the indicators.
Basically the ADR says that they are only required if at a certain angle the front corner indicator is not visible. But if you look at your front corner indicators they have a bit that protrudes at the edge with a second bulb. This allows the indicator to be seen from a greater angle to the side (and rear) of the car than would be otherwise possible. So some compliers obviously felt this covered the ADR while others were not certain and took the "its better to be safe than sorry" option.
correct.
personally, id luv to rip mine off and fill in the holes...
Edited by 32line
Here's my Midnight Blue Pearl R32 GTR. I couldn't find any members rides or intro threads so I thought I'd post some pics up here.
A few minor mods so far:
Engine:
Apex'i intakes and pods
3.5' 5zigen exhaust
Suspension:
Apex'i N1 coilovers
Nismo front and rear strut braces
Wheels and Tyres:
19 x 9.5 Axis Deepdish in shadow finish with 265/30 ZR19 Nankangs
Interior:
Nismo 320km/h cluster
Momo Race EVO steering wheel
Nismo leather gear knob
ICE:
JVC DVD headunit with 3.5 screen
Pioneer 6.5 splits
Pioneer yellow cone coaxials
Kicker L7 12' square sub
Kicker 1000W RMS amp
Kicker wiring
Hope you'll like it. :thumbsup:
Travis.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
