You know what - I wouldn't mind you taking my 32 GTR so I can get a pic like yours
I don't have the gonads to drive it like that ^ lmfao
maybe one day .......
Edited by Sinista32
Picked this up a bit over a week ago :)
Special thanks to my mate for taking the photos. If anyone in SEQ wants some quality pics taken at a reasonable price, PM me and I'll give you his number.
Edited by kawasakirider
