  • Replies 67
just an update - booked the car for the install on friday at 12pm at RE customs - should have it back either at the end of friday
or on monday if i cant pick it up
hi guys
The #2 GB thread is out. The GB will end 19 July. Please confirm your interest there. i have put some names down already from people who expressed their interest. can you please confirm in new thread if still interested etc.
cheers,
Michael
