I am currently running 18psi through my RB20 with a Gt2530 day in and day out, and it runs fine, beautiful actually.
I was wondering what the theoretical boost limits would be for a standard internal RB20, and this model of turbo. Saw some of the guys have been running 21psi, 22psi with similar setups.
Running a Wolf3d v4 and eboost.
The engine's history is fairly uncertain, but it has been running a consistent 18psi for at least the last 2 years, and the car has been drifted and thrashed fairly hard, although it runs fine currently.
On a cold morning it is a bit spluttery and misfirey, but once she is going, runs fine.
Obviously 18psi is not what you would call 'safe' for a reasonably old engine, but would like some advice.
https://www.sau.com.au/forums/topic/121089-highest-safe-boost-on-standard-rb20/
no such thing as "safe boost"
turbos all flow different amounts of air, different motors ingest different amounts
As long as you have a solid tune, and you check the health of the motor before screwing large amounts into it.
It should be fine
By check the health of the motor you don't mean pull the head off and check the head gasket e.t.c. do you? Because thats way too time consuming for my liking.
Obviously all turbos flow different amount of boost... but the fact that the 2530 is a very popular option for the RB20, I assume there are plenty of memebers running 2530 on stock internals, I was looking for some members, from their experience, to tell me what kinda boost they have run on similar setups.
Yeah im running 18 consistently now, was looking to go for something like 21psi when the weather cooled down, which is starting to happen now.
Just wondering whether anyone else consistently runs 20+ through the turbo on stockers...
Might just have to run 21psi on dyno days only?!
have you not read one post in this thread?
Is it just that you have to be involved in every post on the forum because you are a moderator, or do you just like revving people up??
I asked a simple question, so far one of the posts was from someone running substantial boost through the turbo and engine, which is what I want to know. You obviosuly dont have the setup I am talking about...
Which posts is it that I am supposed not to have read R31Nismoid??
Is there 10 posts hiding there saying that someone ran 21psi and blew their engine up, and I just didnt notice them ?? Because thats what I am trying to find out...
he is involved in every post because this is a section that he moderates.. and also he is fairly knoledgble i'd say your biggest risks are tuning.. and yes do the search that sydney kid recommend.. i notice your from townsville i'd be careful with who you get to tune it.. and i cant reccomend anyone from cairns that could tune it safely either as wolf is not highly used up here and the few people that do use it.. i wouldnt trust them tuning my pushbike
as said (already). It is NOT a question of boost. Boost level really is irrelevant in this thread with the mods supplied.
Read my first post, if you dont understand it thats fine, ill be more than happy to explain more.
If the tune is good, the motor is healthy, it will be ok
The Wolf3D was tuned originally by Ricol in sydney with an aggressive tune for about two years, and now it has been tuned by TMS in Townsville. AFR is in the mid-12s to keep it relatively safe. Engine appears to be healthy but obviously havnt done a compression test so not sure.
How much does a compression test cost roughly?! I guess its probably worth it...
hahahaha yeah ive noticed that they dont seem that good up here. Wont be here all that long, prolly move back to Sydney or Brisbane in a year or so...
I am probably more worried about the amount of boost the engine can handle stock, I too have been told that 2530's are able to handle in the vicinity of 25psi, so obivously that isnt the weakest link. The turbo seems fine on face value, it has a nice spool down when I turn the engine off and everything, although thats not exactly a perfect diagnostic tool...
Obviously there have to be a few people that have blown their RB20's ip, what kinda boost did it??
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
