hi guys,
i just bought my first R34 Skyline and finding it hard to believe that i can only get 300kms per tank when cruising on low boost (6psi).
i understand that they drink alot, but cmon surely i can get more out of this motor? ive recently had a service & tune but ive been told by other rb25det owners that i should be getting more kms.
Can anyone suggest a place that specialises in tuning these motors?? VIC - Melb
cheers
Steve
Fuel consumption that severe could be the O2 sensor if you're doing lots of city driving, if you're not it may be pointing at something a bit more drastic.
I'm getting ~330kms from full to empty light first coming on and I've got ~180rwkw and drive it quite spirited most of the time.
If your car is stock standard I'd expect to see at least 450km or more when the empty light first comes on.
Sorry don't personally know of anyone I can recommend down there
Last time I think I read that Nissan want $400+ for a o2 sensor... Repco replacement for the Ford is around $80 :laugh:
I think I might give that a go too... although, when I plugged in the consult gear, the o2 wasn't reading anything abnormal???
EL falcon for around $82 from Repco.
Ive read numerous times that an O2sensor is good for only 40000kms, after that replace it.
My Stagea had shitehouse fuel economy, had 80000kms on it when I got it, and got around 230kms per tank (65litres), now after having the O2 sensor replaced I get 430kms per tank (around 60 litres).
I changed my O2 sensor.. TWICE, and it makes no difference. I checked both new plugs with some consult software, and they were operating correctly.
I've read hundreds of posts, and I don't recall anyone every saying that it fixed their fuel problems (apart from above) or gave anything more than 20km extra to the tank. =-[
It's not a magic fix, it seems.
I'm now searching for any kind of results from tuning AFR's with a SAFC.
Edited by RANDY
Yeah my O2 sensor doesn't affect my economy as I'm mainly doing more than 2500rpm...so the ECU is controlling fuel delivery. My O2 sensor is also a bit screwed with the ceramic/platinum tip snapped and rolling around in the end of the sensor (gives it really slow response)
whilst I might get way more kms then before, I should state that the Stag has spent a few hours on the dyno with 2 tuning stages, first tuning a SAFC (fuel went from ~230 to ~360), and now with the sitc, if I mother it a bit I'll be in the low 400's as stated, if tromped a lot on boost then high 300's (all before fuel light comes on).
replacing the O2 sensor, I feel, worked in my case. as far as getting GTR ones, Im not sure, Im poor and only have the lowly rb25.
ill have a look at the o2 sensor.
I have a 3.5" exhaust and ive also got a power fc that isnt installed yet. Will it help getting it installed????
The Power fc doesnt have a hand controller, so should i buy one or get a mechanic to tune it. are the hand controllers easy to use?
im also getting a back fire in between gear changes, could this be a possible sign for the o2 sensor??
cheers
Edited by Tough R34
i get about 12l/100km's... you can't really say i get such and such for a whole tank, because the tank is 65, but if you fill up when the fuel light comes on, you'll get like 45 litres in.
i've been doing 15litre fills the last 5-6 times, and getting around 120-130km's from that (when fuel light comes on) which works about to be about 12l/100km's...
you get a bit more accurate idea if you work out the litres/100km as opposed to a "tank" - check how many litres you actually get in the car, when the low fuel light comes on... you're not going to get 60-65 litres in that's for sure
Tough.
Yeah that was me.
I like your wheels. They go well with our colour.
If you haven't tuned your PowerFC, you will get some fairly good returns from a good tuning session.
Backfiring between gearchanges says much to much fuel is being supplied.
Talk to Ice or Racepace or any other reputable tuner and get it tuned.
You'll love it.
I get about 320klms out of 50 litres with normal driving.
If I stick the boot in, I can almost watch the needle going down.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
