Hi Guys,
i just bought my second r33 about amonth ago, i no longer have the first one,
anyway i thought it would be good if i could get your feed back and tell me what you guys think or what i should do next and what is safe for my car,
someone told me the turbo is a gtrs turbo and someone else told me its not all tho its a ballbearing turbo but
not a gtrs, is got hybrid front mount and HKS EVC, am runing on 1.1bars and it gave me 252kw at the last tuning i did, so am assuming the car is got stock everything i mean as in, shafts, cam gears, coils, injectors, i think the sparksplugs are gapped otherwise i would have back firing like hell but i dont. i bought it from an importer who dont know much about what the car is got.
the car is a 97 ser II, doing 72Kms
so what you guys think is this safe or should i change a few things,
if you need more info about the car let me know
Thankx in advance
Sorry guys am still new to this,
is got an F-Con-V Pro, 3" from cat-back and 2" or 2.5" from turbo to cat
standard fuel pump
standard injectors alltho they r purple in colour, thats what the tuner told me
am assuming the turbo is a Garret GT860rs, is that a ballbearing turbo..?
i've just tuned the car 2 weeks ago it was heaps rich b4, but now its all good, the tuner said its all good just dnt boost it more then 1.1bars, i dont want more then 250kw atm, i hardly use it anyway
so what you think anything else needs to be done..?
Marckus
https://www.sau.com.au/forums/topic/121118-252wkw-on-my-new-r33/
so it does. you might expect a bit more, but it sounds about right to me.
i just got 233rwkw from a t3/4, motec, 15psi, bigger fuel system (everything), full 3" exhaust, fmic.
as long as your fuel system is up to it, sounds like a pretty sweet package. you might want to do a surge tank setup.
he must have a bigger fuel pump to be getting 250rwkw+ out of it.. the stock fuel pump shouldnt be pushed for more then 240rwkw.. im getting 232rwkw with GT2530, SAFCII, 3" split turbo back, custom manifold, POD @ 16psi and my stock fuel pump was starting to max out..
[quote name='slip' surge tank setup.
surge tank setup..?
Is it worth contacting the previous owner mate maybe he knows if it were me id want to know all the details. it say it would have to have after market injectors, fuel pump and posibly afm.
I bought it from an importer first driver in Aus
my brain must be programmed to ignore it when i read it i think that lowly of them :)
Sorry i did edit the post after your first comment
if you say so, because it actually gave me 262rwks on 1.2 bars and the tuner said lets leave it on 1.1 and 252Rwkw, just to be safe,
When i boost it a cloud of black smoke come out, so am assuming because is got stock injectors and stock fuel pumb they are working at 100% 110% to produce that power,,..? could be possible..
Thankx for your comments so far guys
a typical surge tank setup would be your standard fuel pump pumping fuel into a mini tank in the boot, and then a higher flowing aftermarket fuel pump sending the fuel to the fuel rail/injectors. This way theres always fuel available in that little tank, the stock pump just keeps it topped up, and the big pump gives you enough flow to safely make that power. youll be able to find heaps of pics if you do a google search, or look in "time for na power, the wait is over" thread in the NA performance section on this site.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
