Specifically suspension, subframe, brake and other drivetrain photos and info from the likes of the Gibson Motorsport R32 race cars. Engine mods (and cheats...?) info. Anything from the golden era of Skylines in national and international circuit racing. Thanks.
Maybe this help a bit?
groupagtr.pdf
Some suspension and under body photos;
My favourite, rear LHS note the HICAS dissabled via the replacement bar (no steering rack).
The rear brake ducts
Some more pictures to come
:ermm: cheers :D
Edited by Sydneykid
The Bathurst spec fuel system in the boot. The two large cylinders either side are the dry brake fittings for refueling.
The mechanical (high pressure) fuel pump was driven off the inlet camshaft
The fuel rail, injectors and inlet system (note the standard throttle bodies and fuel rail)
More pictures to come.
:P cheers :D
Edited by Sydneykid
The coolers, in Bathurst spec it had 7 coolers;
Rear diff
Transfer case
Gearbox
Engine oil X 2
Radiator
Intercooler
The Gearbox, Transfer Case and Rear Diff Coolers
The RHS engine oil cooler, there was also one similarly placed on the LHS.
:P cheers :D
Edited by Sydneykid
thats the most awesome skyline of all time i reckon, love the quality of the finish of everything on that thing :D
just wondering whats that little round plate on the side of the plenum for? is it a burst plate incase it overboosts?? similiar to the ones on the supercharged doorslammers, etc?
that car looks like sex on wheels :P
cheers for the pics sk, anyone got any others???
what sort of turbos were they using in those days? n1's or something bigger and better? anything equivilant to todays style turbo setups like 2530s, etc? or bigger?
what sort of hp at wheels were they putting out? i remember reading over 500hp or something?
Edited by CruiseLiner
Yes, they were sure nicely made, Fred sold a couple to customers, around $300K was the rumoured going price. That's equivalent to $650K in 2006 money.
The turbo's where the unbiquitous steel turbine "Group A's", as per the regs.
Due to their total dominance, CAMS limited the boost and made them fit a blow off valve. That's what the round plate on the inlet plenum is for.
They first appeared with around 550 bhp that quickly grew to a bit over 600 bhp unrestricted. Then dropped to ~475 bhp with the boost limit.
I do have some more pictures, but they don't really show anything that isn't shown in the above selection.
:) cheers :D
Great pics, thanks for sharing! A few observations:
Whilst someone posts on the build quality, it may have been awesome back then, but now we have the mega spending of teams like the DTM and WRC cars, ducts are vac moulded in carbon, roll cages are far more complex and efficient, brackets are milled and anodised, the whole shebang is costlier and "prettier". How times, expectancy, and spending have changed! :(
What is the ecu (HUGE....) that they ran?
Any detailed pics of engine water cooling mods? Here in the UK some of the best known RB26 tuners take steam pipes from the water gallery pipe that runs parallel with the intake plenum, back to a swirl pot, to take any steam pockets from the head. Hard to see if that's the case in these photos?
Whats the header tank in the RH bulkhead corner of the engine bay?
The low pressure side of the fuel system, in the boot, looks heavy and complex, is this because everything has a back up in case of failure?
Did all the Group A cars run custom suspension links, hubs and uprights?
If not, how was rear bump steer, which from my mesurements on a stock R33GTr and GTS-t, dialled out? It appears a lot of toe in on rear roll is engineered into the stock rear suspension, and is proving undesirable to me.
Finally, roughly how many proper Group A and JGTC Skylines were built, and although I see quite a few R32's in photos, of course, and some R34's, it seems that the R33 was never represented in such numbers? Do many come up for sale in Oz?
Thanks again for posting all this. More very welcome!
Whilst someone posts on the build quality, it may have been awesome back then, but now we have the mega spending of teams like the DTM and WRC cars, ducts are vac moulded in carbon, roll cages are far more complex and efficient, brackets are milled and anodised, the whole shebang is costlier and "prettier". How times, expectancy, and spending have changed! :laugh:
Hi Chris, sure there is a change in materials used, but the quality of the fabrication, regardless of materials, is the impressive part.
1. From memory the ECU is an Electromotive, they also made the Nissan ECU’s for the LeMans prototypes
2. The water head tank is located just in front of the RHS strut tower. It has 3 connections, one to the cylinder head and 2 to the radiator. Note that the radiator was mounted lower so as to give room for the airfilter box and ambient air feed for the turbos. So the high mount header/filler tank was necessary.
3. The fuel system is the endurance race spec, so it has back up/redundancy system plus a 2 lap reserve with a lower pick up in the tank.
4. The Group A regs allowed modifications in the suspension arms. Conceptually because they were running slicks it was considered a safety issue. The standard components may break under the loads.
5. Bump steer (front and rear) was zero over 80 mm of sprint race suspension movement. I know the endurance race spec was different due to the weight of fuel.
6. I believe the Gibson guys made 5/6 in Australia, 2/3 for overseas customers, 2 team cars and 1 local customer car (the GIO/Windscreen O’Brien car). In Japan I saw one grid of over 20 X R32GTR’s in the one Group A race. The ones I have seen overseas are not anywhere near the Gibson standard, they were considered by Nissan to be the best in the world.
7. From memory Group A was discontinued by FISA before the R33GTR was released, so I don’t think there are any Group A R33GTR’s. SuperTourers took over in the rest of the world and V8SuperCars here.
:) cheers :D
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
