Basically started off with a random breath test on doncaster road near westfield. Blew clear, then like 20m down the road another lot were set up - the EPA for random emissions testing.
My mate got defected in his brother's 300ZX TT tonight - too low, bald rears and no number plate lights. What interested me more was that he passed the EPA random test. I will check with him tomorrow, but i'm pretty sure that this car has gutted cats... What worries me now is that if i get random EPA tested, will my car pass the emissions test...? It has a 'race cat' but i suppose the question really is - can the car still pass emssions without the cat?
Has anyone ever been random checked by the EPA?
https://www.sau.com.au/forums/topic/12152-epa-random-tests/
OK, by what i know, they do the whole noise test and emissions test on the spot, i guess they'd do a look over of your engine bay too.
But still, CAN the car pass the emissions test without / with a gutted cat? Does anyone know?
https://www.sau.com.au/forums/topic/12152-epa-random-tests/#findComment-217713
Faulty or no CAT will definitely show up on EGA as they will get a high hydrocarbon reading. I haven't seen the equipmeny they are using at the moment but I'm reasonably sure they haven't changed the way they check. As for the $10,000 fine, I've never heard of this being issued against any individual.....has anyone else?
https://www.sau.com.au/forums/topic/12152-epa-random-tests/#findComment-219017
Hey Inasnt
I went for my EPA test at Macloud today... (I was suppose to go last week, but I had put it off till this week)
I passed the noise test right on the nose at 90db !!!
talk about close....
As for Emissions test - didn't even test it.. he said skylines run very clean - so he didn't bother to test it... The fact the my Low Fuel Warning Light was glaring him in the eyes while he did the noise test may have atributed to his desission not to do the emissions test.. :P
But the big thing is that the Sound test was done at 5100 rpm
(not the usual 3200 rpm that the exhaust shops test at)
He said that a Twin Turbo 2.6 L has to be tested at 5100...
At the EPA they work off a more detailed Vehicle Reference Book then the epa approved exhaust shop test centers have...
And as the test centers don't have the detailed book - they test at the default for a NA 6 cyl. which is 3200rpm....
They also also asked me if I had changed my exhaust since my last EPA test in november 2002 when it tested at 85db at an exhaust shop test center... I said "Yes, I changed it when I got this latest epa notice... if I am going to get epa notices while running with a 85 db muffler then I might as well run one that is 90db"
He said "fair enough" and passed me :P
Originally posted by INASNT
opps misread that!
Ring up a few exhaust places, 1 of em should have 1, not nuttin special from when i had to go to epa in mcloud to get mine done
https://www.sau.com.au/forums/topic/12152-epa-random-tests/#findComment-228871
Guest INASNT
sideways
they tested my car at 5100rpm 2. I was gonna ask them wtf they were doing but since it only read 83db with thew stock exhaust i used for that day i didnt say anything.
My car was actually running rich as they told me coz i put back on all the stock stuff which changed all the flows. Did a tall guy with glasses and grey beard test your car?
https://www.sau.com.au/forums/topic/12152-epa-random-tests/#findComment-229384
  • 1 year later...
i think theyre supposed to test at around 3/4 of the redline
for engineers certificate for my rb25 silvia, it test was carried out at 5625 (3/4 of 7500) and did 89.5 dBa on (what i think is) a 2.5" full exhaust with canon (exhaust pics here)...this is nsw though, not sure on differences with vic
https://www.sau.com.au/forums/topic/12152-epa-random-tests/#findComment-879634
i would like to say ive been done with epa on saterday night i have no cat i got $2000 fine for waste and poulltion as i wasent sure on this in vic as i still have my south aussie plates still on my car as they didnt defect me just fine me and belive me it ant worth not haveing one it sucks for all those who dont have a cat belive me get one the fine is 2 rich and they said they catch me again and i still dont have it fixwd they well double the fine and they keep on double it until u get one so go and getone mates
https://www.sau.com.au/forums/topic/12152-epa-random-tests/#findComment-881984
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
