Hey hey,
Started this project a little while ago, and now that its done thought I'd put some pictures up...
Basically I originally wanted sat nav in the car, but when having a look at the prices I kinda thought that it was a bit much just for sat nav, and I checked out what other possibilities there were… GPS usb receivers ;)… I then decided that I’d just get a computer in the car and that could run everything, as in sat nav, music and whatever else (if there would be anything else)… Used the MP3Car forums heaps to get a good idea of how others had done it and designed my own little PC…
Hardware:
Via EPIA Mini ITX Motherboard (1.3Ghz)
M2ATX power unit
1Gb Ram
80Gb SATA Hard Drive
USB GPS Receiver
7” Touch Screen
Software:
Windows Xp
RoadRunner
FreeDrive
Winamp
Started off with the screen… I bought another dash surround so that I wouldn’t have to drive my car around for weeks/months without a dash :(
7" Touch Screen 1
7" Touch Screen 2
7" Touch Screen 3
Took the screen apart so I could mould the front of it to the dash and once finished I could screw the rest of the screen straight to the dash, the idea was that I wanted it to look like one piece, and that the same time there is no way you could steal unless you broke the screen…
For it to fit nicely under the climate control I had to cut part of the dash at the bottom, also has to take a couple mm off each side.
Dash 1
Dash 2
Dash 3
Dash 4
Once I got it fitting nicely in the dash I used Araldite to glue it in and the used putty to bog up the sides and sand it back to make it look like one piece.
Dash 5
Dash 6
This came out pretty good, so I put it in for painting…
Painted Dash 1
Painted Dash 2
When I got the dash back, I popped the screen back into it and with the moving/playing around with the dash over the next couple days the front of the screen that was glued to the dash cracked and eventually with a little bit of force it came apart completely. Took some advise from someone in Bunnings and got it plastic welded to the dash… this time before I puttied it all up and made it look good again a gave it some severe testing to make sure it wouldn’t crack again (sorry no pics of this part…)
While the dash was getting re-painted I started to build the case. I wanted to build it in aluminium, but cost and putting it all together (or bending it) just put me off using it… I used persplex instead :P
I wasn’t too sure where I wanted to have the case, couple of options… in the boot, under the seat behind the screen (in the dash)… Decided to go with fitting it under the seat, so I made a model of the case and had it under the seat until I realised that every time I went over a bump I could feel the case, so scraped that and decided to put it in the dash… Took the dash apart and again made a model of what I wanted it to be like and made sure everything fit nicely then made the case…
Case 1
Case 2
Case 3
Case 4
Note that its actually sitting the other way around now, can see this in a later pic…
At some point in time while I was making the PC I got the dash back…
Final dash
When I was happy that everything was going to fit nicely I finished the case and installed all the software on the machine… tested everything to make sure it would work. As I had the dash back and I’d put it all together I was running it on the 7” screen to see what it would give…
Case 5
Case 6
Case 7
Case 8
7" powered off car pc
Finally got to the stage when it was all ready to go in… spent a good couple hours messing around with it all to get it to fit like I wanted… (very tight fit ) cables everywhere in the pic but was nice and neat once it was all in…
mess!
Put the dash back in and bingo…
Final setup 1
Final setup 2
Pics aren’t the greatest and the glove box still on in on the pic… once I have given the interior a good clean might take a final pic and post it…
At the moment ironing out a few little issue… the main one is sound… playing only MP3s on the hard drive (have 2 USB ports so this is how I add music etc when needed)… the prob with MP3s are the recording levels they are recorded at.. some songs sound awesome, others sound like c#@p! just trying to find some other 3rd party software that will regulate the output of the sound… but yeah… apart from that everything is working sweet… :)
https://www.sau.com.au/forums/topic/121951-in-car-computer-d/
  • Replies 136
Few moe Q's if you dont mind.
Where did you get the persplex from? Easy enough to manipulate?
The 3.5" drive works fine? Lots of ppl telling me to go notebook but I want a 3.5" Drive (250gig - Lots of movies and music). :(
How does the Via board handle as well? The onboard video decent?
Thanks for the replies :P
Here are the links to the software;
FreeDrive
RoadRunner Homepage
RoadRunner Forums (on MP3Car)
Alpha, it doesn't mute the sound completely reduces the volume level and a nice little voice tells you where to go:)
Liiger, Persplex bought from Bunnings... once you have the shape you want and you have cut it out (my house mate found the best way of cutting it... we got a pen knife, heated it till it was red hot then cut straight throught the perspex :) very "home made" but hey, it worked :() to bend the sides, pretty much the same, used one of those little blow torches heated the persplex, bent it to the angle and waited for it to cool...
The 3.5 drive has been in there for a couple of days, maybe give me a little more time to check it out and i'll get back to you ;) for the moment it doesn't seem to mind any sideways action :)
Again, for the moment, the motherboard is working a treat, haven't had any issues with it... still early days though... and as for the onboard videos, its fine, tell you what, when you are watching something on a 7" screen, you dont really need a $1000 video card ;) but looks good (just remember to put the codecs on the machine BEFORE you put it in the car! LOL!)
if you had the chance to do it again, would you change anything?
maybe a few things... i would have taken the buttons on the screen off... there is a way to wire up the power switch to automatically turn on, and off... and if you need to switch between VGA and video input (rear view camera for example) you can use the remote that comes with the screen... might also add some alternate power, eg you can plug it a 12v power supply instead of using car battery when doing updates, or testing stuff out... had it on for about 45 minutes without the car being turned on and the battery didn't like it too much... (had the music/amp running as well...)
but for the moment... i'm happy with how its all hooked up...
Primordial, never thought of that, but thanks that sorts out my power issue :)
Rekin, GPS receiver is on the metal bar that runs accross the car behind the dash, works the same under the dash or on top... i get the same signal...
Alien, power unit in the computer has an ignition wire, when ignition on = PC on... ignition off = PC shutdown procedure...
Where is your GPS receiver located? Doesnt it need a clear view of the sky in order to pick up satellites?
My GPS receiver is located on the back parcel shelf. It sits between the speaker and the window. It's black and only about the size of a matchbox so you cant even notice it's there. The only reason mine is located here is that my PC is under the drivers seat, so that was the shortest length possible. The GPS receiver needs line-of-sight to get a decent signal. When looking at the graph showing the satellite distrobution, the satellites located in front of the car have very low signal (due to the roof being in the way). The satellites behind the car get excellent signal even through the window. You only need 3-4 satellites to get a proper reading, and there is usually more than 20 satellites in view wherever you are.
Alien, it was pretty labour intensive coz I pretty much did everything myself, except for the painting of dash... But I did take my time, all up started doing research in late march, then bought GPS receiver and used laptop as test machine to test all software, when all was working properly, prob started buying the parts in mid april...
cost around $700 after having sold old head unit and all... but haven't pulled out every invoice coz i don't wanna know exactly how much it cost :) motherbaod and screen prob the most expensive parts...
Hey Parish very nice mate!
I'm going to be making one up soon, but I'm going to do it the lazy way and get a motorized in-dash screen! :)
Hey with Roadrunner do you know if theres a way to embed programs such as Oziexplorer rather than have it run seperately? I noticed that your GPS s/w you are running was within Roadrunner.
cheers mate!
when you turn the car on, what happens? Do you have to manually turn the computer on and then wait for it to load up the OS and all programs?
I manually have to turn mine on. I've hooked up a switch which is located just under the steering wheel, on that little panel (R33). Single press switches my laptop on. Single press again then sends the PC to Hibernate. If i forget to hibernate the PC, it automatically hibernates when battery reaches 90% so that the PC doesnt crash from no battery power. I'm running a laptop though - slightly different setup to parish.
Personally I would recommend the laptop option if you can buy one cheap off ebay with a cracked screen or something. They are designed to be moved around more than PC components, and you dont have to worry about things stuffing up (as things usually do with custom PC's). Laptops are made to be shifted around, so they will marginally be able to cope better with the jolting of the car. I'm not just talking about the hard drive, but the motherboard mounts etc. The mini-pc option is sometimes cheaper though if you cant find a damaged laptop.
cheers mate!
Check out Centrafuse too mate. Front end software is a matter of preference. Personally I have never like RoadRunner, but heaps of people do like it. Centrafuse is quite popular too, but is trialware for now. By the end of the year you may have to buy it if you want to continue using it. It's in beta testing for free by the general public now (you and me! :P). The best thing about centrafuse though is that it has EVERYTHING bundled into one neat installer package, and is really easy to configure. The only thing you will need is the maps for Destinator (80mb off torrents). This is the same with any front end software though, you need the maps. I found RoadRunner and it's GPS software (separate plugin sort of thing) very frustrating to install and configure.
Centrafuse: http://www.fluxmedia.net/
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
