hey gents
just thought you might like to see some incar from the nsw dutton airport 500 mtr sprint, reduced from
1000 mtr's as it was bucketing down, we were pretty happy too as the car was topping out at a bit over
220 klm across the finish line for the 13.5 sec
http://videos.streetfire.net/video/cb3caa6...6af6cc9b498.htm
cheers russ
hey gents
cheers russ
Nice vid. Have you got any other stages online? Be interested in seeing them.
Car 9 from WA in Feb - incar from both driver and co driver:
http://video.franzonline.net/DuttonWA/
Cheers.
hey there
top quality vids there !! great sounding car
could you give me any tips to get decent sount?? just using mics that cam with a lipstick camera at the moment.
this video is wakefield cicuit but not from the dutton
http://videos.streetfire.net/video/BAC0B0F...0B297B03720.htm
auto salon circuit battle
cheers russ
hi roy
thanks mate, the car was awsome
nice rotors in ya gallery!
Yeh sadly i dont think im goign to be able to use them, having 2nd thoughts about running 18" wheels and carrying all that weight when for a GTST they are massive overkill...perhaps 340 is the money. Need to beat Snowman and brakes will only slow me down :D
But, i would still lve the engine, gearbox, brakes and rims from your car...oh and the seats. You can keep the shell though :D
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
