Pitty the place is a shit hole. no water, no power, toilets 2km away, no showers, poor PA system. if it wasnt for good company last time i would never consider camping there again.
For sure!! The people at WB are awesome and nothing is too much trouble.
  • Replies 218
No water- yeah its called a drought
Id put up with all the things you listed at WB anyday over the sht way WSID is run.
WSID is the only track we refused to tow to when I had my dragster and I will never ever go there to race or spectate-would rather burn my money than spend it there.
As for more peolpe getting involved from these forums and else where-well thats not going to happen with the current state of play with import drag racing at the moment-I think the scene will struggle to hold onto some current long term members, let alone attrached new ones :(
Edited by gtr660hp
I cant wait for Jambo and if SRWD doesnt have any AWD or 4WD then I have a better chance of being top qualifier.... :/
Adrian,
your not going to make the trip up just because you wont get any points towards your championship?
When we were there in September last year there was a shit load of water!!! Almost 2 inches through the whole venue!!
Adrian
Thats an understatement to say the least....i reckon there was at least 6 inches in the corner of my tent.....water that is...lol
the rule book is out mother fuggers
AWD have there own class, looks like a tussle between the big heav cressida and the light weight 13b mx5 for top qualfier, unless calros comes out int he millenium supra, then we have no chance, 10.04 at 150 mph last year witha 2.3 sixty foot. theres a high 8 in that car
hahahaha you make it sound like your at a disadvantage..... I probably wont get a chance to practice before the event as my axles are 3 weeks away :ninja:
10.04 @ 150mph is pretty impressive.... I dont think my car has a chance going that mph.
Whats the link for the rule book.... I was at the site but it didnt appear to be downloadable...
No trans brake is ok, I havent got mine sorted out yet anyway.
Running alcohol wont affect me either. I might see if I can afford to buy some C16 for the event and up the boost.
Any other exciting changes?
Adrian,
are you going to enter this series?
no aftermarket transmissions
so no powerglides, c4's no supra gearbox behind rotary etc.
if it wasnt an option from the manufacturer its not allowed.
thats interesting and will certainly limit the class.
unless carlos shows up with his manul box in, he wont bein our class.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
