How many people bring their GF's/BF's To cruises?
  • Replies 48
I took my girlfriend to one of the TNS pizza runs 2 the Northern Beaches. It was her 1st cruise and she enjoyed herself.
Shes a vegetarian so she doesnt come out to the steak nights:D
Most cruises have a mixed group of people and everyone usually has fun .
anyone else's gf complain about induction noise? or is it just me? he he and i just fitted up some teins - should be interesting to get her thoughts on the 'harshness' of the ride now :D
hmmm, but yeah, generally, unless shes really into cars, cruising etc, i think its better for all concerned if she gives it a miss - its not wat she likes, so y force her?
Originally posted by cereal
There's no question as to who wore the pants in that relationship.....:D :D :)
hehe well considering he's now an ex....that would be me ;)
(although I mostly wear skirts lol)
Now all i need is a guy who's into cars as much as me and I'll be happy :D
my gf came to a couple... and she found them boring.. and most of the time ive gotta leave early because of that..
she wont come to the TWS akira meets on saturdays anymore cos it's a "guy thing" and cruises.. she thinks they're a waste of time...
im trying to go alone..but i dont know if its possible!~ she still persists to come, then say it's boring and wants to leave
Shell: Now all i need is a guy who's into cars as much as me and I'll be happy
You can take me anytime Shell....:uh-huh:
Its not that I like your car, its more the fact that your legs look soooooooo good in them skirts when you push the clutch in.:drooling:
Originally posted by shruggz
i couldnt date a girl with a better car than me.. i'd be too interested in her car... and be jealous every time she kicked my arse off the line...
but then again, you could get cheaper mods for buying in bulk....
Same...but then again.. i'd be driving her car all the time.. :D
Originally posted by Duncan
Kelly always drags me along to cruises and track days :)
just tell her Duncan!!...put your foot down and say "Kel, this weekend, we're going shopping" :uh-huh:
QIK78U, you were sposed to be checking out all the skylines, not my legs!! ;)
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
