Hey guys,
This is a picture of a Hybrid kit we did for a member,
Basically the piping goes the same way for the R33 Greddy kit.
Also all pricing for kits are now $699pick up in NSW and $750 delivered Australia wide, getting orders in on Friday, let me know asap,
Only $200 depsoit required
  • Replies 52
Fangz- Are you after the whole kit, but with piping to the custom plenum instead?
Jonjon- I know the i can't get the MSpecs for the r34, i'm nto 100% sure why and i'm not sure if it's becuase there a realitivly new product on ther market, however i'll try and remember to ask the guy next time i'm talking with him and he might be able to ask the trust/greddy rep for future reference.
im def interested in one of these greddy intercoolers however im still debating whether the vspl (or spec-v as its now known) is the one i should go for. putting the shiny-ness of the piping aside, on the trust website theres a chart for each intercooler on its performance. under the heading 'response' (the point on the pentagon at around 2-oclock) it shows the vspl cooler as being the best followed by rspl then the m spec.
http://www.trust-power.com/02greddy/intercooler_new.html
my question is this... is the mspec going to lag like a biatch? :teehee:
im not going for high rwkw but i def dont want a laggy skyline
any input is greatly appreciated
cheers!
Edited by prosman
Prosman - Ok well basically for starters the general rule is a tube and fin cooler will always flow better then a bar and plate cooler, so it all depends on your set up The v-spl we have seen take up to 300kw and the M-Spec is rated slightly lower, around the 260kw mark. But depends on your application, there will not be a major lagginess but the v-spl will always be slightly more responsive.
JON JON- when the kits arrive i will be asking someone if i can trial fit a M-SPEC kit on an R34 if you like you can volenteer, most of the R33 kits will fit an R34 anyway but Greddy dont plan to release one as yet offically.
The R34 has the washer bottle in the way where the R33 pipe goes, so this will have to be moved.
  • 1 month later...
rekon this would be better than a Hybrid 600x380 ??
theyre $699, but seeing as this is a 'big name' jap brand i would consider it if its gunna be better quality, even thought its smaller :S
although ive only ever heard good things about Hybrid.
Hey guys,
Daniel here from PlatinumPPI i will explain whats happening,
We are offering this as a group buy, but basically we need 10 people from this forum and the nissansilvia forum combined to offer it at this price or the thing wont happen, therefore it is a group buy.
The first order will be next week, but if the interest is good, we will run it again for those who miss out.
THIS COOLER IS GENUINE GREDDY NOT A CHEAP CHINESE COPY, THEY ARE JAPANESE DESIGN.
Please see here for more information: http://www.nissansilvia.com/forums/NEW-GRE...er-t168736.html
is the intercoolers made in japan????? or are they designed in japan?????
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
