I just got off the phone with Constable Woods from Riverwood Station. My car just been found and is now in their posession. I'll be calling them tomorrow to get the details and hopefully take her home. Apparently it was just a joy ride and left it at Punchbowel.
I do hope the thieves get caught but nothing could describe how relieved and happy I am at the news.
A big thank you to all you guys and your kind words, and especially Liz for cheering me up.
OMG THIS IS AWESOME!!!! I feel whole again.
Edited by lingeringsoul
https://www.sau.com.au/forums/topic/122772-yay-my-car-has-been-found/
  • Replies 42
Excellent News dude. Glad you got it back.
btw i think your referring to Sergeant Woods. Good friend of mine. My teachers husband to be exact.. hope you don't mind if i ask him about it?
no problem go right ahead and ask
Very good news, Now lets hope they catch them. Missed you last time you guys were in newcastle, now there might be a next time. Cheers and hope she isnt to worse for wear! :D
apparently, it was just damage to the ignition when they stuck a screw driver into it
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
