Power House ER34...
Guest neoGT-25
 Share
Guest neoGT-25
hey all, i am thinking of a mod list for my car when its time to turbo it...
I would like to use my engine that i have now because it has less K's than an older RB25DET... :S
ok heres what i am thinking about (please tell me what you think and make comments or sugestions or whatever, most of what i say wont make sense scince im pretty car dumb)
Keep in mind i dont really want a drag car... just a VERY tough track/street/drift car :S if that made sense? bah... heres the list
some form of a high torque TRUST turbo...?
TRUST Wastegate & manifold?
TRUST FMIC of some form (ive heard they are better than most intercoolers?)
A'PEXi POWER FC
full A'PEXi N1 exhaust system
A'PEXi RSM
TEIN adjustable suspension?
Brembo break kit?
internals obviesly (what things should i change?)
what sort of clutch would i need?
what other stuff would i need and what sort of pricing am i looking at for these components?
any help is appreciated :D
byes :burnout:
i don't know much about the late model rb25's, but one would think so. Got to look at compression ratios and how the boost will affect it i guess, might be easier to put a new engine, or even easier to look for a new car.
Guest neoGT-25
NOOOOOOOOO i love my car... and my engine dosent have many K's on it... other cars can handle turbo so why couldent mine? like theres civics, mirages, 323's, lancers that have been turbod... why wouldent mine handle a turbo?
The internals, are not stock on those.
nismo_boy is right, and the money ud spend on upgrading the internals on your current engine is better spent on a straight swap from a gt-t r34. afaik the turbo engine has more cooling paths in and around the cylinders and block so its going to last longer and if the stock neo rb25det doesnt sate your need for power you can always put stronger internals into it and run even more power than you ever could through your rb25de with a turbo strapped on the side for good measure
So who here has made their non-turbo a turbo with stock internals? Oh wait that's me! YES it can be done, yes you can make your car haul ass, BUT you have to know your limits and accept them...
For those who are interested my old n/a - turbo 32 is still kicking around Rocky, buggers me how it's still going but it is...
Guest neoGT-25
hey people... if you noticed... at the top of my first thread i said not now but when im ready for it "i am thinking of a mod list for my car when its time to turbo it... " :P LOL, no one listens... i dunno wanna swap my engine i just wanna change my internals ;)
and i want a high torque turbo... what sre some high torque turbos? trust ones? :D
meh, byes all :)
when the time comes, buy a neo 25det and 5spd gearbox incl standard ecu. you can extract more power more easily.
and most likely cheaper.
I was lucky enough to get the conversion parts cheap enough so
i turboed my 25de and its still goin fine - although my clutch is giving up the gig after 60,000kms of extra torque it was never meant to see.
to get serious turbo action from that car u'd have to look at lowering the compression in your engine to see serious boost levels, which would mean pistons and gasket. get nismo ones. and then to optimise ur turbo, i'm thinking hks 2830, which is one big turbo, u'd need camshafts, get hks ones, which would mean u'd have to change ur valve springs and retainers, possibly valves as well becos ur ones wouldn't be made to flow turbos.
and then u'd have to change ur exhaust system completely to accomodate the turbo. don't forget cam gears.
u'd need a good front mount to cool down the air too, hks or nismo items do the job well, as will trust items.
don't forget u'd need an improved fuel delivery system as well. injectors, fuel pump better fuel rail and the works.
by then u'd want a serious management system to maximise fuel efficiency, so u'd be looking at probably power fc or motec.
and to put that power down properly, u'd want serious wheels like volks 18 inch rims and good tyres.
of course u'd wanna stop, which would mean brakes upgrade.
and u'd probably need a new twin plate clutch to handle that power, not to mention ur driveshaft, which isn't made to handle the projected 600bhp.
u'll probably be looking at over 70 grand worth of parts, which doesn't include labour.
so my advice would be to take that 80 grand or so and buy a gtr.
 Share
    • Yeah, so I think that is the point. If you presume a 25% lower reading on a chassis dyno than what the engine is making, then the most you would see from a 720HP engine is ~550wHP. "Lose" a little more because AWD dyno and the number will be lower. Call a hub dyno "wheel HP" and you should see higher numbers. But the horses would be a different size. And as Murray says above - an imposed 90% DC limit drops 550 down to 500 straight away. 80% takes you down to ~450.
    • Sounds reasonable to me.  Do you know what your injector duty cycle is? I guess everyone has their own personal limit as to how high they want to flirt with 100% duty cycle, but who knows what your tuners limit is. Maybe they like to cap it at 80%? Now your injector CC to HP conversion has a 20% hair cut on it, then through drivetrain losses, yeah 500rwhp seems ok to me.  If you plan to spend on your GTR, modern injectors and a modern ECU will go a long way!
    • @GTSBoythanks for replying. That's realistic and I always believed in the injector-hp rule of thumb. I am however making way less than that 😕 My guestimate/goal for the setup is a reliable 500rwhp, R33 gtr, seems realistic enough doesn't it?
    • 720cc injectors can only support about 720 engine HP. Maybe a little bit more. 600rwHP is, um, a plenty big chunk of that number. Probably running to the top of your fuel supply.
    • Hi gents, sincerely asking you guys the theoretical or actual power figures expected from the setup below: HKS Y pipes & 80mm cat back, Sard (denso) 720cc injectors, DW300 pump, R35 MAFs, Twin HKS 2530's (stock headers), Trust intercooler, stock BOV, stock intake plenum & TB's, N1 oil pump, MLS head gasket, forged pistons, poncam B's, Power FC, pump RON97, nismo coppermix twin plate, 18's on 265 rubber. So I've pretty much listed all that matters with regards to making and putting the power down. Asking as I may or may not be getting the full potential of my setup (bottom end was running 600rwhp on a different car). I have done numerous Dyno sessions with slightly different setups but more or less the same outcome which leads me to conclude (reluctantly) the setup is maxed out. Will share graphs but would like you to share your input first for better effect. Thanks in advance, guys!
