Hey all, been meaning to ask for a while but kept forgetting.
I have a fair idea of cams but not entirely the effect of them according to their lift / degree's.
Ok, so my understanding is that cams have lift, and I assume that this relates to how high the cam goes when rotating. However, I dont know what the degree's mean or how any of this gives different power gains at different RPM... Engine internals are certainly not my strong point.
Thanks
C
https://www.sau.com.au/forums/topic/123200-cams/
depends on the setup.
usually more lift = more flow, but you also need duration. the problem lies in getting a good combo as at high rpm you can get valve slap, eg over revving. to compensate you can use tougher valve springs etc. but it depends on the lift. if the lift is more than the springs can take the springs will bind, or over compress.. VERY bad.
if you need high revs eg nat asperated, you need less duration more lift... to raise the rev range
use as a guide as this may not be correct to some out there ;)
Edited by bogcock
https://www.sau.com.au/forums/topic/123200-cams/#findComment-2275388
So for an internally-stock GTR, you wouldn't want much lift, is that right? I think the tomei poncams are 262 and 10.2 and are supposed to be good for stock engines with bolt ons.
Thanks for this info too.
https://www.sau.com.au/forums/topic/123200-cams/#findComment-2275394
poncams are good because they use the stock valvetrain.
if you want big power you will need more lift and around 264 duration..
procams are better, but you need to change valve springs, retainers etc
for a stock gtr (internally) cams wont really give too much benifit. ive seen stock cammed gtrs running 600hp with no problems. attend to other parts 1st, such as turbos, ecu, injectors zorst etc
Edited by bogcock
https://www.sau.com.au/forums/topic/123200-cams/#findComment-2275428
Christian - i went for std turbos, tomei poncams 260 9.15mm.
It made a huge difference to the midrange and drivability.
Someone else on here also did poncams on std turbos...
Full list is:
1.1 bar
turbo back exh
stock airbox, high flow filter
poncams + adj wheels
i reckon area under the curve is pretty good, and low down power...
sure turbos would have made more power, but drivability is very much improved... and I don't drive b/w 5000 - 8000 rpm all the time - 85% if the time is between 2000 and 4000 rpm
don't completely discount cams ;)
https://www.sau.com.au/forums/topic/123200-cams/#findComment-2275514
Yeah between my 2 GTRs I have done mods quite differently but gotten similar power, but the power is very different.
Old GTR;
Power FC
Full Exhaust
More Boost
243rwkw
New GTR;
Cam Gears
FPR
Full Exhaust
More Boost
250rwkw
But the way that power is produced on the new GTR is astounding compared to the old one and I reckon its all cam gears.
Poncams are only $850-ish delivered from Nengun, not sure how much fitting is tho.
https://www.sau.com.au/forums/topic/123200-cams/#findComment-2275909
Bit OT - but whats the diff between a PonCam and a ProCam ?
Hi B-Man
I have just been doing similar research on cams also, and have found that while all the specs seem similar on the poncams and low end procams (eg 9.15 lift, similar durations), the procams are apparently a more aggressive "ramp" affecting the speed of valve opening. This means that the procams need the uprated springs where the poncams dont, and presumably affects the power/torque delivery.
The Tomei website has some good info in Engrish describing the cams.
Cheers
Ned
https://www.sau.com.au/forums/topic/123200-cams/#findComment-2275926
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
