Nope, if you remove the fuse or fit a toggle switch your R32 GTR/GTS4 becomes 100% RWD. You also loose ABS while in 2WD mode.
Dirt Garage sell the switch option in the group buys section. I bought one and fitted it, easy and works great. To switch between Atessa and RWD the car just needs to be stationary.
https://www.sau.com.au/forums/topic/123207-gtst-4-2wd/#findComment-2275614
actually you can switch to 2WD without disabling ABS. you just need to remove the 4WD fuse from the fuse box next to the battery. much better way to do it. but if you just want it to do a quick burnout before a drag etc then using the cabin 4wd/abs fuse is fine.
car does not need to be stationary to switch to RWD, but does need to be stationary to switch back to 4WD. you can actually go into RWD on the move without a switch. just switch the engine off as you are rolling, then start it up again before you come to a complete stop. you are now in RWD and can do your burnout or whatever then when you next come to a complete stop the car will go back into 4WD.
https://www.sau.com.au/forums/topic/123207-gtst-4-2wd/#findComment-2275627
I've used that trick a few times in my gtr too. Whilst in gear and rolling flick the key off and on and it goes into rwd. Must confuse the computer or something. As soon as you become stationary it engauges 4wd again.
Ive also found that if your 4wd light won't go out you can flick the key whilst stationary and often it will engauge 4wd again.
https://www.sau.com.au/forums/topic/123207-gtst-4-2wd/#findComment-2275897
when you start the car the ABS computer goes through a self check. as the car is rolling (the wheel speed sensors are moving) the ecu cannot satisfactorily complete the check so it disables 4WD and ABS.
https://www.sau.com.au/forums/topic/123207-gtst-4-2wd/#findComment-2276183
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
