I have a number of parts for sale after taking my car back to standard and selling it.
The parts I have available are as follows
Ohlin's shocks and wanabe springs $900
Caster rods adjustable/rose joints $150 sold
Caster rod brace( cusco) $120 sold
Rear camber adjustment arms/rose joints $120 sold
Sub frame bushes $50 sold
Will sell as a complete pack for $1100. excellent upgrade
Nismo 1 way mechanical diff in housing with flanges to suit GTST $700
Plenum front mounted throttle body $500
throttle body $80
Cable to suit front mount $100
Piping to siut front mount plenum and intercooler $180
FMIC $250
Sell as a pack for $950
Exhaust mainfold. Japanese made,stainless steel,T3 flange,ceramic coated,port matched.
$700 ono
ROH Drift R rims with tyres. 235/40/18", 265/35/18".
Pirelli and sports contact 2 respectively. 50% tread
$2000
I will listen to offers as long as they are reasonable.
If you require photo's leave a bump/pm and I will send it to you. I having trouble attatching photo's on the site
cheers
Edited by gtstcruiser67
https://www.sau.com.au/forums/topic/123212-r33-parts-for-sale-in-sydney/
hey mate can i get pics of the following to [email protected]
Cheers, very interested.
throttle body
FMIC
Sell as a pack for
throttle body
FMIC
Sell as a pack for
I will send it to you tommorrow
thanks for the interest
throttle body
FMIC
Sell as a pack for
pm sent
Ca you please send me pics of
throttle body
FMIC
to
[email protected]
Thanks.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
