Hi guys,
If we remove the 4wd fuse (gtr34 v-spec) to measure the rwkw on a 4wd dyno, what will affect or damage to the drive line??
In normall driving condition (without torque split), is it true that the gtrs are running permanant on 25% front and 75% rear power??
Any explains would be appriciated, CHEERS !!!
On 34 gtr, remove 4wd fuse and front driveshaft and it'll run on RWD mode.
Do a search as this topic has been covered many times.
Why you want to run RWD on 4WD dyno?
Cheers
Grant
What the mechanic did is fine on an R32...
R33/34 - consider the equivalent of slipping the clutch for the entire dyno run.
take a poke through the forums, have a search and I am sure that there will be a technical thread about it . Understand WHY it is not a good idea (its not...).
but i would not put it on a 2wd dyno without removing the fuse like in the 32gtr. i am unsure about 34gtr but i beleive its similar.
Its not similar. You won't damage the R32 like that.
Edited by ebola
as I mentioned, we had to run it in rwd mode (on a 4wd dyno) because during the tuning the 4wd check light came on and the torque didn't split at all. So the mechanic took a risk !!!
mentioned where? call me blind but in this thread you havent said anything about that
Anyways...
Please search, common topic this is for GTR owners.
And if your mechanic doesnt know this... i wouldnt take the car back there as they have no idea (obviously)
To answer the question briefly, the shaft MUST be removed.
This is crucial. Just pulling the fuse will still cause wear to the clutch packs in the 4WD transfer case as its not in "true" RWD mode with the drive shaft still connected.
yess. just incase. any awd post r32. you cant just pull the fuse as youl burn out the transfer case.
as its "preloaded"
as a general rule. if the cars got 2 drain plugs on the transfer case you can. if its only got 1 plug. you cant
I did search about this attesa controll topic, but I haven't satisfied because all GTRs can use after market torque split controlls (such as an HKS unit for example) to adjust the desire split levels. I've seen some footages about street drag in Japan, gtr33 and gtr34 did a massive burn out b4 they lined up. Hmm, how did they manage to do that without burning the clutch packs in the transfer case???
What I'm thinking is when we adjust the torque controll module at 0, means no torque transfer, isn't this equivalent to remove the fuse ( no torque transfer too) ??? can any one make this clear?? CHEERSS !!
why keep asking opinions if you are not going to beleive them?
the correct info is in this thread. 32 is fine to run in rwd mode indefinately due to different attesa pump preload on the plates in the transfer case. 33 and 34 all 4wd systems always have some front drive.
we make attesa controllers. They modify the signal to the computer to go rwd only, but that does *not* change the preload in later models so we recommend not using rwd mode in 33 and 34.
And a burnout is one thing (let the case slip for a while), and they may have line locker for the front brakes, but a dyno is totally different. What would happen if you have the rear on the rollers, start to spin the rollers, wheel speed sensors show rears are slipping so computer sends torque to the front wheels. I don't want to be standing nearby.
Mashrock: yeah its true now go back into your room and talk to the little fairies and stuffed toys that talk to you.
Either you have no idea or youve been smockin to much crack
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
