Hey fellas, as i had my car on the hoist the other day i noticed i had pretty bad camber wear on the inside of my back tyres.. And considering the prices for 18 x 10 265's are not cheap! I called Pedders and the quoted me $190 per Camber arm + fitting... a total of $530! it was a joke honestly... I love the way it sits but it will cost me too much on the long run with having to change tyres every 6 - 12 months
Can anyone please recommend what else i can do to get my camber problem fixed?
Regards,
Sarkis
https://www.sau.com.au/forums/topic/123495-camber-wear-on-tyres-help/
JJR Rear Upper Adjustable Control Arms Price: $149 (Pair)
Suit Skyline R33 GTS-T, S14 & S15
justjap.com
hope that helps
Ed
My only concern with aftermarket suspension arms is the issue it may cause over the pits or insurance should one have an accident. For offroad use.. fine.
unless these items have been approved?
Grab the whiteline items, you can't go wrong.
I have series2 R33. I puit the whiteline adjustable arms on it. gave me what i needed and seems good quality (saw some cheap imported stuff that scared me) If to expensive. Superpro or probably even Whiteline will do camber adjustment bushes, but doubt you will gety same amount of adjustment.
Regards
R Dirty 3
Regards,
Sarkis
Whiteline camber kits on the Group Buy as follows;
http://www.skylinesaustralia.com/forums/in...showtopic=85467
Excessive negative camber is directly related to height. This is what is usually needed for each height increment, note that all measurements are centre of wheel to guard;
Standard (new) height is 380 mm front and 370 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
Note that 350/340 is the best height for handling and ride comfort
:) cheers :P
Hi i have seen rear camber kits for R33's on Ebay for a $149 a set .. Besides i wouldnt go to pedders any how they are over priced and over rated in their products check out the link..
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...AMEWA%3AIT&rd=1
Regards,
Sarkis
Sorry to hijack the thread, but i got wear on mine, but it is only the inside inch, enough to blow my tyre any ideas??
Whiteline are in sydney dude. Give them a call direct if you arer intereseted in their control arms. Becareful of some of the cheaper arms on the market. Quality is pretty low and i would not like to find out what would happen if they failed at 100kph on freeway.
Regrds
R Dirty 3
go to a tyre or suspension shop and get them to match the toe to the camber. that will greatly reduce the tyre wear.
All that means is instead of wearing the tyres out fast only on the inside, it wears out the whole tread fast. It’s a band aid, the proper answer is to fix the excessive camber
:ermm: cheers :(
Had my car up on a hoist today and took some pics. I have tein adjustable (height and damper I believe) coilovers and this is what my rear tyres look like.
Is it bad wheel alignment etc or just this camber issue?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
