Hey fellas, as i had my car on the hoist the other day i noticed i had pretty bad camber wear on the inside of my back tyres.. And considering the prices for 18 x 10 265's are not cheap! I called Pedders and the quoted me $190 per Camber arm + fitting... a total of $530! it was a joke honestly... I love the way it sits but it will cost me too much on the long run with having to change tyres every 6 - 12 months
Can anyone please recommend what else i can do to get my camber problem fixed?
Regards,
Sarkis
https://www.sau.com.au/forums/topic/123495-camber-wear-on-tyres-help/
JJR Rear Upper Adjustable Control Arms Price: $149 (Pair)
Suit Skyline R33 GTS-T, S14 & S15
justjap.com
hope that helps
Ed
My only concern with aftermarket suspension arms is the issue it may cause over the pits or insurance should one have an accident. For offroad use.. fine.
unless these items have been approved?
Grab the whiteline items, you can't go wrong.
I have series2 R33. I puit the whiteline adjustable arms on it. gave me what i needed and seems good quality (saw some cheap imported stuff that scared me) If to expensive. Superpro or probably even Whiteline will do camber adjustment bushes, but doubt you will gety same amount of adjustment.
Regards
R Dirty 3
Regards,
Sarkis
Whiteline camber kits on the Group Buy as follows;
http://www.skylinesaustralia.com/forums/in...showtopic=85467
Excessive negative camber is directly related to height. This is what is usually needed for each height increment, note that all measurements are centre of wheel to guard;
Standard (new) height is 380 mm front and 370 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
Note that 350/340 is the best height for handling and ride comfort
:) cheers :P
Hi i have seen rear camber kits for R33's on Ebay for a $149 a set .. Besides i wouldnt go to pedders any how they are over priced and over rated in their products check out the link..
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...AMEWA%3AIT&rd=1
Regards,
Sarkis
Sorry to hijack the thread, but i got wear on mine, but it is only the inside inch, enough to blow my tyre any ideas??
Whiteline are in sydney dude. Give them a call direct if you arer intereseted in their control arms. Becareful of some of the cheaper arms on the market. Quality is pretty low and i would not like to find out what would happen if they failed at 100kph on freeway.
Regrds
R Dirty 3
go to a tyre or suspension shop and get them to match the toe to the camber. that will greatly reduce the tyre wear.
All that means is instead of wearing the tyres out fast only on the inside, it wears out the whole tread fast. It’s a band aid, the proper answer is to fix the excessive camber
:ermm: cheers :(
Had my car up on a hoist today and took some pics. I have tein adjustable (height and damper I believe) coilovers and this is what my rear tyres look like.
Is it bad wheel alignment etc or just this camber issue?
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
