Seeing if anyone knew if the R34 Neo 5spd manual transmission will work on the R33 RB25DET?....I have an S13 right now with an RB25 in there and had the stock R33 5spd, but it gave out and cant find that many R33 transmissions around. Found this R34 Neo transmission that I can pickup, but wanted to make sure that the bell housing would bolt up to the back of the block without a problem and also check to see if it is the same general overall size so that I wouldnt have any troubles with the tranny tunnel or driveshaft that I had made for the R33 setup.
Thanks
https://www.sau.com.au/forums/topic/123533-r34-neo-transmission-on-r33-rb25/
yes it will.
youl need the shifter and a pull clutch/flywheel asembly.
either.
r33gtr or r34gtt. 250mm clutch :)
i had one in my dr30. nice box with good ratios and very smoth operation.:wub:
I am about to fit an R34 box into my 33GTSt. (Auto to manual conversion)
Can I use an R33 GTR flywheel with a pull type clutch?
  • 2 months later...
so has this been done before? does it fit straight on without any mods (apart from the flywheel/ can R33 flywheel fit?) or is there more to it and if there is plz explain
Edited by assyrian4evaa
as T04GTR said, all you need is the gear lever and pull type clutch.
everything else bolts straight up.
  • 4 months later...
Why do you want to put a r34 box in it?
Works out cheaper to put the 33 box in doesn't it? And push type clutches are cheaper....
I just got my car back from a manual conversion So just curious
P.S help me out here: http://www.skylinesaustralia.com/forums/in...howtopic=154422
I got an R34 box as it was all I could find at the time.
Push type is cheaper.
For your conversion you need the wiring harness from the gearbox up to the fuse/relay box on the drivers side inner guard for the reverse lights to operate.
For the speedo to work you need the manual speedo gear drive in the box and a manual speedo head or it may be easier to buy a complete cluster second hand.
Dont ask me why Nissan have a manual and auto speedo head, but they do.
Hope that helps.
Stan
Edited by Stan
Thanks
Buy the R34 box and swap the front housings over, i just finished doing this 26 conversion with R34 box in S13 ( www.uras.com.au/democar.htm ), i hate pull clutches so used a R32 GTR housing but R33 GTst works exactly the same.
Edited by URAS
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
