finally got my GTST back today after 2.5 months or repairs...
I have fitted Matts (Mavric) custom banana bar however I havn't installed my FMIC yet which is just sitting in the garage...thats next weekends project.
Anyway after much debate about grilles I went with a stock grille cos I thought it would be nice with the color...anyway too late now regardless..:D
Here are some pics without my good rims If any1 is looking for a front bar that fits perfect (cos it required now adjustment at all)...ready for a FMIC I would be looking at this bar...
Edited by khunjeng
https://www.sau.com.au/forums/topic/123563-my-ride-is-backfinally/
please man get rid of the grill... a letterbox scoop is cheap as and would increase the toughness by 15%!!
other than that, its very nice... same colour as my old liner!!
I agree, should be black or black carbon fibre...a quick spray can job would fix that...
Choices only cost time or money to fix...if you got it wrong...
Rest looks nice and clean...
Edited by 700HP-GTR33
**mesh now in black...
the grille is going as soon as the FMIC is one in a week or so so I'm not too fussed, However I agree with the grille color sux...wasn't oo happy when i saw it but ...funny enough I just went to find the black paint I used to paint my other one...so should be done by later today...
not the biggest fan of the letter box style.. Also the ones I did try didn't fit properly anyway - and I tried a few.
lets see how it looks without the silver...black is the go.
Edited by khunjeng
lol thanks Dez...and yes it was a case of look at me :) I'm on the ring road most mornings between 8-9am...getting off at sydney/hume exit. Now I might be in the line instead..
Edited by khunjeng
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
