got a quick couple of snaps of my painted sideskirts when i test fitted one of them.
now i need a front bar to match the height of the skirts as it looks funny now :( rear bar is fine but the front one is sooo high off the ground and the skirt is about 90mm from the floor
i dont know if fitting the skirts is a good or bad thing as its looking more like a hoons car everyday with brakes, bodykit, lowering, exhuast and i bought it for the purpose of not having to worry about cop attention.
Edited by CruiseLiner
lmfao its an addiction
lmfao...
Please explain in long hand.
Brad, what you should be doing is sourcing a 'see through' bonnet for that motor.
I got the same skirts - from Qikstagea. Probably for the same reason as you - wanted to fill in the middle of the car and give it a lower look without modifying the suspension.
For the uninitiated these are Nismo style kits and the bottom of the skirts are level with the bottom of your existing mudflaps.
Since I'm already up for a fibreglass job to repair the crash damage, I might see if i can raise them a bit.
now i need a front bar to match the height of the skirts as it looks funny now :) rear bar is fine but the front one is sooo high off the ground and the skirt is about 90mm from the floor
Who cares about cop attention, although i do know where you are coming from as that is the reason i got rid of my silvia for the stag, but f*&k your car is SEX
IM IN LOVE :(
Brad like i always say..sex on wheels champ..that car is lookin sweeeeeetttt...anytime you want to take me for a drive???
by the way i LOVE the side skirts :devil: your car is seexxxyyyy :P
thanks guys and girls its lookin alot nicer than when i got it, i just need to put some better rims on it and it will be how i want it :devil: maybe front bar upgrade as i said earlier is on the list and some rear brembo brakes to match the fronts.
going up curbs with the skirts are interesting and only clear by about 20mm when on a 45 degree angle to the curb, i think speedhumps are out of the question, luckily its not a daily driver.
thanks again :P
Looks great Brad,
You do need a front bar and wheels to match (my opinion) as the skirts are really fat and the first thing that catches you eye now, probably due to the fact they are so low. Sick car though!
Cheers
Luke
Mr RS4 - great to see you back again mate...... still got a pic of your car on my HD (was in a yellowish well-lit carpark, looked sexy as!!)
Brad, looks great mate. If you ever do sell those mags drop me a PM with a price. I think that the front bar looks ok as is tho, but hell its your car, lol.
Hey Guys, new to the steaga world >_< , here are some pics of mine. Got big plans for this car, but a good starting block. :miner:
Ps. Thanks to AlexCim and his mates for the pics.
Edited by -NismoR32-
Hey Guys, new to the steaga world :laugh: , here are some pics of mine. Got big plans for this car, but a good starting block. :yes:
Car looks awesome! I want similar style wheels for mine, but first I need to get the suspension sorted - mine sits so high, it's not funny!
Nice shots, Alex - I might consider doing the same sort of thing next time I take my car out for a few photos...
  • 3 months later...
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
