hey ruby rs4, luving the black series 2, is that how the car came, with the front bar? is that just a standard nismo one is it? wat about the grill? did you paint it black youself?
the bar is from vivagarage.. how'd it fit roo?
the grill is standard
visited the parents and tested out their new camera. canon sx1. tell you what it takes a nice photo for just point and shoot auto mode, and the HD video is good too. after taking photos, realised camera was not set to "fine" mode. bugger.
Edited by Jezboosted
No. My S2 originally came with a Dayz bodykit. I since removed it and fitted a Dolphin kit and now I changed the front bar, yet again, for an Aero type M bar from Viva Garage. The grille is standard, I just took the double unicorn off. Got a Viva grille coming.
Altho my S2 came with Nismo badging on it, I'm trying to figure out what makes it so "Nismo" special? It has a Momo wheel, and some chrome handle on the back of the tailgate, Nismo badges, it did have GTR style rims (since replaced with 18"), but I'm still yet to discover any other items. I've seen a "Nismo" special Stag on ebay, but his looks more stock than mine (it doesn't even have Nismo badging). So I reckon mines a proper Nismo stag, but not fully aware of all the Nismo touches I'm sure.
noticed you've changed your front bar ruby, is there some place that makes them or somthing ?
Yep. Viva Garage here in Adelaide :)
roo that bar looks rather Viva garage like? How is the quility of it and was it direct bolt on?
Are you leaving it matte?
I drilled all the required holes myself and it bolted on no problem, altho the indicators took a bit of fiddling to fit.
No, I'll be painting it gloss black, but couldn't get it into the shop before the car show this weekend. So it goes in matt black for now. Didn't want to do a rush job.
I've been thinking about getting the entire Stag resprayed Satin Black. :laugh:
Edited by RubyRS4
That Viva bar looks great on your car mate and you pic just helped me heaps..
I have a S1 with the same dolphin kit and have been tossing up weither to get a Viva Type M bar or another Monkey Warehouse Nismo bar as mine is cracked to the sh!thouse and your pic just made up my mind :(
Edited by SHIZNT
i realise this, however he bought a copy locally from viva >_<
I realised that as well, my response was more for BCK34 as he saked what style the bar is.
MIKE have you worked out what re-spray colour your car is?
i'll pm you also, but im pretty certain it is 'athlete silver' (i believe that's kv2?) it came on bnr34's
nice stag bubba, ok peoples so after waiting nearly 2 months i have finally got my new rims on my stag hope yous like, (and if ya dont, TOO BAD i do hahahah)
I've got a nice lip that would fit nicely on that front bar of yours :)
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
