Anything can do anything...there are variables though. Are you going single turbo, twin, can you get a loom cheaply. Do you already have the R32 GTST Pfc???
hmmm could go both ways on the turbos... not sure bout the loom and i already have the 20pfc
Cheers
https://www.sau.com.au/forums/topic/123946-rb20det-pfc/#findComment-2289284
